What Does Your Watch Say?
Charter Member
$285 CAD shipped OBO
Caravelle 666 feet Devil Diver
Model 3286-DP
Circa 1974 (date code N4)
Bulova caliber 11DP hand wind movement (date code N3)
Citizen 0241 base movement
17 jewels
Solid steel case
Original dial, hands, case, crown, crystal and movement
Steel screw down case back
Bi directional rotating bezel
Case measures 39mm wide 44mm lug to lug and has 19mm lugs
Case shows some well with no polishing
Dial shows well
The luminous material still glows
Luminous dot is missing from the 1 o'clock
The bezel insert is a replacement
Movement winds sets and runs plus (+) 20 seconds dial up over 24 hours
Model 3286-DP
17 jewels
Solid steel case
Dial shows well
