outsnowboarding
Bronze Contributor
Delta T NBS bronze
Purchased this big beast directly from Bobby on here about a year ago if I had to guess. It's a great piece in fantastic condition with just some surface scratches on the case back. Showing some patina on the case as per usual. It comes complete as a kit the way I received it from Bobby. The MSRP on these was an insane $1400usd just looking to get $400. May be open to interesting trades but mostly looking for a straight sale. The info I grabbed from the delta t website is below :
Movement:
Japan Miyota Automatic Movement Cal. 8N24
Manual/Automatic winding
21 jewels
21,600 vibrations per hour
more than 40 hours power reserve when fully winded
Hands:
Lumed Hour, Minute hands
Case:
49mm diameter excluding crown
66mm from lug to lug
20.2mm thick
Aluminum Bronze
Satin and Sandblast finishing
Screw-down 316L Stainless Steel Inner Bottom Cover with Mirror finishing Logo
316L Stainless Steel Outer Bottom Cover
Three Main Screws locked Bezel and Outer Bottom Cover
Automatic Helium Escape Valve
Dial:
Antique Style Dial with Lumed index
Windowed Dial to see-through the Balance Wheel and Pallet Fork
Crown:
7.7mm diameter with cross-diagonal pattern screw-in Crown
Crystal:
Sapphire Crystal with anti-reflection coating
Water Resistant
1,000m/3,300ft (100ATM) Water Resistant
Sent from my SM-N975W using Tapatalk
Movement:
21 jewels
Hands:
Case:
20.2mm thick
Aluminum Bronze
Dial:
Crown:
Crystal:
Water Resistant
