morethan1
Gold Member
Condition
The dial and hands are in very good condition. The dial has some black marks at 2 & 6 o’clock markers. The bezel insert is original and has a marks and dings all around. The bezel clicks solid as it should.
The case has a few dings shown in the pictures. The case has not been polished. The crown screws down nicely with 1.5 turns. Watch keeps great time, serviced Feb 2017. All gaskets have been replaced (except the crystal gasket which is still good). New aftermarket domed crystal (@crystaltimes). New Seiko OEM flat vent strap on new spring bars. This 6309 comes with a HK dial which reads "movement and dial japan cased in hong kong"
Specifications
Brand: Seiko
Model: 6309-7049
Year: Circa Aug 1987
Material: Stainless steel
Diameter: 44mm (excluding crown)
Thickness: 13mm
Lug width: 22mm
Crown: Screw down
Bezel: Bi-directional, indexed w/60 clicks
Crystal: Hardlex
Caliber: Automatic 6309
Water resistance: 150m
Box & papers: None
Asking: $525 shipped
Specifications
Brand: Seiko
Model: 6309-7049
Thickness: 13mm
Lug width: 22mm
Crown: Screw down
Crystal: Hardlex
Box & papers: None
