morethan1
Gold Member
Condition
The watch keeps excellent time. The original case has no dents or scratches. The dial and hands are in excellent original condition. The crystal is original and has some scratches. The shroud is original, it has been cracked at 12 - 1 o'clock. The bezel insert is original and turns easily both ways. The strap is a new Seiko OEM flat vent strap with new fat spring bars. Original inner and outer box included. All functions work perfectly including the light, alarm and both push buttons. Last battery change April 2019.
Specifications
Brand: Seiko
Model: H558-5000
Year: Circa April 1982
Material: Stainless steel
Diameter: 46mm (excluding crown)
Thickness: 12mm
Lug width: 22mm
Crown: Screw down
Bezel: Bi-directional, indexed w/60 clicks
Crystal: Hardlex
Caliber: Quartz H558
Water resistance: 150m
Box & papers: Box only
Heritage
The Seiko H558-5000/9/A was the first dive watch to have a hybrid analogue digital setup with digital alarm chronograph functions. The watch was later called "Arnie" since Arnold Schwarzenegger wore it in “Commando”(1985) and “Predator”(1987). In order to build a watch that was rugged enough for the toughest adventures Seiko engineers tested it to -40°C and up to +60°C. The watch was used on expeditions to the North and South Poles as well as by an international team of explorers that climbed Mount Everest in 1988. With other features such as three time zones, chronograph, alarm and backlight, the H558-5000/9 is also a great ‘tool’ watch.
Asking: $935 shipped
Specifications
Brand: Seiko
Model: H558-5000
Thickness: 12mm
Lug width: 22mm
Crown: Screw down
Crystal: Hardlex
Heritage
