System
Gold Member
Selling my October 2021 Omega Seamaster Diver 300M Co‑Axial Master Chronometer 42 mm. This watch is a catch release for me, I decided to let it go as white dial is not something that I initially thought would work for me.
Ref num. 210.30.42.20.04.001
This watch has the balance of a 5 year warranty from a Canadian Authorized Dealer.
The watch is in great condition crystal is absolutely clear, no visible to my eye dings or deep scratches on the case, with exception of some on the lugs likely from strap changes under the lugs, however there are some minor ones on top of the lugs as well, could be from strap changes or regular wear, I tried to put them to light as much possible as I could on the pictures. Can provide more pics at request if need be, as I am always trying to be as much transparent as possible with my sales.
Watch comes on Vagenari Bright White Rubber Strap valued at $250 after conversion, shipping and duties (https://www.vagenari.com/products-detail.php?ProId=166),
plus
- OEM Omega Black rubber strap with OEM Omega pin and buckle valued at $400
- OEM steel bracelet fully sticker-ed, only some scratches underneath on one side where bracelet attaches to the lugs (see pics) from a strap change
- Outer cardboard shipping box
- Inner which cardboard box with small damage on the front flap at seam, show in pictures
- Inner wood box in new condition
- Operation instructions manual
- All 3 cards
- Omega soft cloth pouch
- Crystal protective sticker
- Crystal case back protective sticker, still on the watch back.
FEATURES
Anti‑magnetic
Chronometer
Date
Helium escape valve
Master Chronometer Certified
Screw‑in crown
Transparent case back
Unidirectional ceramic rotating bezel
TECHNICAL DATA
Between lugs: 20 mm
Bracelet: steel
Case: Steel
Case diameter: 42 mm
Dial colour: White
Crystal: Domed scratch‑resistant sapphire crystal with anti‑reflective treatment on both sides
Water resistance: 30 bar (300 metres / 1000 feet)
Movement Type: Self winding OMEGA Master Chronometer Calibre 8800
Prefer F2F in GTA and asking $5850 plus shipping.
Thanks for viewing.
plus
- All 3 cards
FEATURES
Anti‑magnetic
Chronometer
Date
Helium escape valve
Screw‑in crown
TECHNICAL DATA
Between lugs: 20 mm
Bracelet: steel
Case: Steel
Dial colour: White
Thanks for viewing.
