Selling a Suunto Elementum Terra. These retail for $900+tax.  $400 incudes a 2nd brand new OEM strap and buckle.  Watch crystal is in perfect shape – not a scratch.
Manufactured in Finland, this watch measures altitude and weather trends and includes a unique 3D compass for adventures in the great outdoors. Designed with stainless steel casing and a sapphire crystal glass to withstand the elements.
Key features • Altimeter • Barometric pressure & trend • 3D compass • Log: last 8 ascent / descent, max. altitude
Technical specifications
Altimeter • Altitude range -500m - 9000m/-1600ft - 29500ft • Real-time vertical cumulative value • Temperature compensation • Total ascent/descent • Resolution 1m / 3ft • Logbook function 8 logs/logbook files
Chronograph: Stopwatch
Compass • Guided calibration • Heading in degrees • Tilt compensation up to 45 degrees • North-South indicator : North indicator
Other • Backlight option for night use • Selectable metric/imperial units • Sapphire crystal glass • Backlight type Electro-luminescent display • Operating temperature -10°C - +60°C / +14°F - +140°F • Storage temperature -30°C - +60°C / -22°F - +140°F • Water resistance 100m / 300ft with underwater buttons • Weight : 200g with steel strap, 95g with other straps • Measurements: 44.7 x 51.5 x 14.3 mm / 1.76 x 2.03 x 0.56in • Replaceable straps : By authorized retailer
Power : Low battery warning
Special: Button lock
Watch • 12/24h • Calendar clock • Daily alarms : 1
Weather • Trend indicator • Sea level pressure • Barometer range 950-1060 hPa / 28,6-31,3 inHg • Barometer resolution 1 hPa / 0,03 inHg
https://www.altitude-sports.com/pro...jM6Y44bhs1Lcotb21uPiEqB6HgU7kGshoCOvcQAvD_BwE
