Sold Red Star Bullhead Unwrapped
docdoowop
Bronze Contributor
Super nice watch with a proven, good looking S-19 movement.
Red Star Bullhead Mechanical Chronograph Watch with Brown Dial #8597G-2
Red Star Bullhead Mechanical Chronograph with Brown Dial #8597G-2​
This new release from Red Star will have you feeling like you are wearing a chronograph from the 1970's. It is modeled after the famed "Bullhead" chronograph design, with the pushers and the crown located at the 12:00 side of the case, giving the layout the distinctive appearance of a bull's head and horns.
Powering the Bullhead is the Seagull ST1901 column wheel chronograph movement, complete with Swan's Neck regulator viewable through the exhibition caseback. Winding the watch is accomplished through the crown, located at the top of the watch. Engaging the chronograph is done by pushing the upper left pusher, and resetting (when stopped) with the top right pusher. Chronograph seconds is the central hand, and chronograph minutes is the upper sub-dial. Running seconds is at the lower subdial.
The bracelet is sized with friction pins, and the perfect fit is achieved through a 3 position micro-adjust clasp. A bonus leather strap is included as well, should you want to change the look. Low light visibility is enhanced with the use of luminous paint on hands, markers and dot on the fixed tachymeter bezel.
Product Features
  • Movement:Seagull ST1901 Hand Wind Mechanical 21-Jewel Chronograph
  • Case:Stainless steel, 42 mm x 14.5 mm, 43 mm tip to tip
  • Back:Exhibition see through
  • Crystal:Double dome mineral with inner AR coating
  • Band:Stainless steel, 18mm, and bonus leather strap
  • Water Resistant:50 meters
  • Weight:150 grams
$270 plus shipping with tracking
Never took the plastic wraps off, but did test the movement and the it ticks fineIMG_0124.jpegIMG_0121.jpegIMG_0122.jpegIMG_0123.jpeg
